Sica 10 S 3 CP - Z006017 - 8 Ohm - TSP
Verfasst: 19. Mär 2019 00:50
hier der aktuelle Sica 10S3CP Subwoofer aus 2019.
Das Ferro -Äquivalent zum SICA 10S3PL (Z006015)
TSP:
Fs = 45.28 Hz
Re = 5.15 ohm[dc]
Le = 1.209 mH (1k)
L2 = 0.606 mH (10k)
R2 = 38.53 ohms
Qt = 0.321
Qes = 0.35
Qms = 3.89
Mms = 64.04 Gramm
Rms = 4.68419 kg/s
Cms = 0.1929 mm/N
Vas = 35.02 Liter
Sd = 357.80 cm²
Bl = 16.374254 Tm
ETA = 0.9036 %
Lp(2.83V/1m) = 93.63 dB
Infos:
Frequency shift = 34.1 %
Signal = PN 2.6V
Wobbel = 30Hz 20m 10V
RE = LCR
EstLE = On
PE = 350W AES
Xmax = 7mm (24-10mm)
Eigenes Datenblatt:
WinISD Pro Alpha File:
Original Datenblätter - neu und alt:
Link zu Sica:
http://www.sica.it/en/product/subwoofer/subwoofer-8
Zusatzinfos:
Messung der Neodymversion:
viewtopic.php?f=95&t=7734
TSP:
Fs = 45.28 Hz
Re = 5.15 ohm[dc]
Le = 1.209 mH (1k)
L2 = 0.606 mH (10k)
R2 = 38.53 ohms
Qt = 0.321
Qes = 0.35
Qms = 3.89
Mms = 64.04 Gramm
Rms = 4.68419 kg/s
Cms = 0.1929 mm/N
Vas = 35.02 Liter
Sd = 357.80 cm²
Bl = 16.374254 Tm
ETA = 0.9036 %
Infos:
Signal = PN 2.6V
RE = LCR
EstLE = On
PE = 350W AES
Eigenes Datenblatt:
Link zu Sica:
► Messinfos
Zusatzinfos:
