Kenford PA200 L200006-8B (Modell 2015) | TSP vermessen
Verfasst: 14. Sep 2015 19:44
Kenford PA200 - L200006-8B - 8 Ohm - Modell Mitte 2015
Loudspeaker parameters:
Fs = 60.52 Hz
Re = 5.69 ohms[dc]
Le = 150.54 uH
L2 = 532.66 uH
R2 = 20.46 ohms
Qt = 0.44
Qes = 0.55
Qms = 2.20
Mms = 18.19 grams
Rms = 3.14410 kg/s
Cms = 0.0003802 m/N
Vas = 25.26 liters
Sd = 216.42 cm^2
Bl = 8.45930 Tm
ETA = 1.04 %
Lp(2.83V/1m) = 93.60 dB
Info:
Added mass = 59.85 grams
Frequency shift = 52.6 %
Diameter= 16.60 cm
Est-LSE = on
Est-Re = on
Wobbel = 5m 35Hz
Signal PN 1V
Kalibriert und Kabel kompensiert.
Re per Messung ermittelt, überprüft per Multimeter.
Masse per kalibrierter Feinwaage ermittelt (0,1g)
