Kenford PA300 FS-W12-4-50 (Modell 2015) | TSP vermessen
Verfasst: 14. Sep 2015 19:44
Kenford PA300 - FS-W12-4-50 - 4 Ohm - Modell Mitte 2015
Loudspeaker parameters:
Fs = 48.28 Hz
Re = 3.49 ohms[dc]
Le = 141.19 uH
L2 = 522.52 uH
R2 = 18.04 ohms
Qt = 0.45
Qes = 0.52
Qms = 3.32
Mms = 51.53 grams
Rms = 4.70824 kg/s
Cms = 0.0002109 m/N
Vas = 88.29 liters
Sd = 543.25 cm^2
Bl = 10.24258 Tm
ETA = 1.92 %
Lp(2.83V/1m) = 98.45 dB
Info:
Added mass = 107.20 grams
Frequency shift = 39.6 %
Diameter= 26.30 cm
Est-LSE = on
Est-Re = on
Wobbel = 5m 35Hz
Signal PN 1V
Kalibriert und Kabel kompensiert.
Re per Messung ermittelt, überprüft per Multimeter.
Masse per kalibrierter Feinwaage ermittelt (0,1g)
Fs = 48.28 Hz
Re = 3.49 ohms[dc]
Le = 141.19 uH
L2 = 522.52 uH
R2 = 18.04 ohms
Qt = 0.45
Qes = 0.52
Qms = 3.32
Mms = 51.53 grams
Rms = 4.70824 kg/s
Cms = 0.0002109 m/N
Vas = 88.29 liters
Sd = 543.25 cm^2
Bl = 10.24258 Tm
ETA = 1.92 %
Info:
Diameter= 26.30 cm
Est-LSE = on
Est-Re = on
Wobbel = 5m 35Hz
Signal PN 1V
