Kenford PA200 DYD200B (Modell 2014) | TSP vermessen
Verfasst: 10. Nov 2014 10:39
Kenford PA200 dyd200b - 4 OHM: (Modell 2014)
Parameter:
Fs = 96.60 Hz
Re = 3.81 ohms[dc]
Le = 70.40 uH
L2 = 287.49 uH
R2 = 13.45 ohms
Qt = 0.99
Qes = 1.27
Qms = 4.48
Mms = 11.64 grams
Rms = 1.764308 kg/s
Cms = 0.000235 m/N
Vas = 15.09 liters
Sd= 213.82 cm^2
Bl = 4.857459 Tm
ETA = 1.14 %
Lp(2.83V/1m) = 95.89 dB
Info:
Added Mass Method:
Added mass = 12.25 grams
Diameter= 16.50 cm
Signal: PN 0,5V
Kalibriert und Kabel kompensiert.
Re per Messung ermittelt, überprüft per Multimeter.
Masse per kalibrierter Feinwaage ermittelt.
Parameter:
Fs = 96.60 Hz
Re = 3.81 ohms[dc]
Le = 70.40 uH
L2 = 287.49 uH
R2 = 13.45 ohms
Qt = 0.99
Qes = 1.27
Qms = 4.48
Mms = 11.64 grams
Rms = 1.764308 kg/s
Cms = 0.000235 m/N
Vas = 15.09 liters
Sd= 213.82 cm^2
Bl = 4.857459 Tm
ETA = 1.14 %
Info:
Added Mass Method:
Diameter= 16.50 cm
Signal: PN 0,5V
