Kenford SBX 2030 | TSP Vermessen
Verfasst: 10. Nov 2014 10:38
Kenford SBX 2030 TSP :
Fs = 41.75 Hz
Re = 8.01 ohms[dc]
Le = 725.52 uH
L2 = 2193.05 uH
R2 = 78.88 ohms
Qt = 0.48
Qes = 0.54
Qms = 4.20
Mms = 27.89 grams
Rms = 1.907528 kg/s
Cms = 0.000520 m/N
Vas = 33.36 liters
Sd= 213.82 cm^2
Bl = 10.942536 Tm
ETA = 0.48 %
Lp(2.83V/1m) = 88.89 dB
Added Mass Method:
Added mass = 12.25 grams
Diameter= 16.50 cm
Signal: PN 0,5V
Kalibriert und Kabel kompensiert.
Re per Messung ermittelt, überprüft per Multimeter.
Masse per kalibrierter Feinwaage ermittelt.
