RCF LF-18 N401 Gehäuse
Verfasst: 4. Feb 2010 13:22
von d!a
da ich schon seit einiger Zeit hier mit lese und auch gerade beim Bau von 2 MT-181 bin hät ich ne Frage von nem Kumpel...
er hat derzeit nen Selfmade Subwoofer mit 2x RCF LF-18 N401. Habt ihr Tips für einen guten Gehäuseplan wo man nur einen davon verbauen kann ? Der doppel 18er wird bisschen schwer langsam....
Danke ;)
Daten des Chassis:
Features
4-inch Inside/outside copper voice coil
2400 Watt continuous program power handling
98 dB Sensitivity
30 Hz 1 kHz Frequency range
Dual-forced air ventilation and 15 mm top plate for minimum power compression
Dual spider design with silicon based dampening control
Triple-roll surround and corrugated straight cone geometry
GENERAL SPECIFICATIONS
Nominal Diameter 460/18 mm/inch
Rated Impedance 8 Ohm
Program Power 2400 Watts
Power handling capacity 1200 Watts
Sensitivity 1W, 1m 98 dB
Frequency Range 30-1000 Hz
Effective Piston Diameter 395/15.6 mm/inch
Maximum Excursion Before Damage 52/2.1 mm/inch
Minimum Impedance 6.3 Ohm
Voice Coil Diameter 100/4 mm/inch
Voice Coil Material Copper
Voice Coil Winding Depth 25/1.0 mm/inch
Number of layers 2
Kind of layer Inside/Outside
Thickness Top Plate Depth 15/0.6 mm/inch
Cone Material No pressed pulp
Cone Design Straight
Surround Material Polycotton
Surround Design Triple roll
THIELE - SMALL PARAMETERS
Resonance frequency Fs 32 Hz
DC resistance Re 5.1 Ohm
Mechanical factor Qms 6.5
Electrical factor Qes 0.27
Total factor Qts 0.26
BL factor BL 27.8 T - m
Effective Moving Mass Mms 201 gr
Equivalent Cas air load Vas 257 liters
Effective piston area Sd 0.122 m2
Max. linear excursion Xmax 8.8 mm
Voice - coil inductance @ 1KHz Le1k 2.5 mH
Half-space efficiency Eff 3.01 %
MOUNTING INFORMATION
Overall Diameter 465/18.3 mm/inch
Bolt Circle Diameter 442-447 mm
Bolt Hole Diameter 6.5/0.3 mm/inch
Front Mount Baffle Cut-out 424/16.7 mm/inch
Rear Mount Baffle Cut-out 424/16.7 mm/inch
Depth 205/8.1 mm/inch
Volume occupied by the driver 5.5 liters/ft3
BAFFLE CUTOUT DIAMETER
Net Weight 9.1/20.2 Kg/lbs
Shipping Weight 9.8/21.8 Kg/lbs
Re: RCF LF-18 N401 Gehäuse
Verfasst: 4. Feb 2010 14:05
Läuft im Gehäuse vom LMB-118 :wink:
Verfasst: 4. Feb 2010 14:09
von d!a
das is doch ne gute info, ohne abstriche machen zu müssen ?
Verfasst: 4. Feb 2010 14:10
Nee, der Treiber läuft in dem Gehäuse schon richtig und nicht nur irgendwie :)
Verfasst: 11. Sep 2010 17:51
von hoppler
ich habe den N401 erst in einem Gehäuse ähnlich dem LMB-118 gehabt. Der klang war voll aber wenig knackig. Tief ging er subjektiv auch. Allerdings fand ich den klang oftmals schwammig. Daher hab ich mir das MHB-46 gebaut von startec. Das ist ein Hornhybrid und riesig und sehr direkt. Kannst du vergleichen wie wenn du das Chassie ohne Gehäuse laufen lässt. Dann ist es knackig und schnell und macht Spass, blos ohne Druck. Und so ca klingt der MHB-46 nur halt viel lauter, aber gut. Geht auf jedenfall nicht so tief wie der LMB. Dafür musst du ihn Stacken. Immerhin hat er Single ne F3 von 49Hz. Bei 4Stack sins dann 43Hz F3. Wer Zeit und Lust und viel Holz hat (sind 4,... qm2) der ist mit dem LMB gut bedient. Spielt sehr gut mir rockigen Sachen und Hardcore. DnB ist schlecht im Single betrieb, weil er nicht tief geht. Allerdings ist es auch ein Horn und trägt somit weit. Angegeben ist er mit nem Wirkungsgrad von 105db 1w/1m mit Halbraum 2pi. Also so 99db auf Vollraum 4Pi
Fazit: Wer nicht viel Teifgang braucht aber dafür knackig, direkt und laut, kann sich nen MHB-46 überlegen im Vergleich zum LMB-118 FÜR DEN LF18N401!!
