Thomann 12-280/8-A | TSP vermessen
Verfasst: 31. Mär 2015 01:00
				Thomann the box Speaker 12-280/8-A 8Ohm
Patameter:
Fs = 67.18 Hz
Re = 6.26 ohms[dc]
Le = 380.92 uH
L2 = 798.66 uH
R2 = 41.93 ohms
Qt = 0,561
Qes = 0.71
Qms = 2.67
Mms = 41,1 g
Rms = 6,49365 kg/s
Cms = 0,0001366m/N
Vas = 59.86 liters
Sd= 555,7 cm²
Bl = 12,36397 Tm
ETA = 2,4859 %
Lp(2.83V/1m) = 97,18 dB
Info:
Added mass = 76.55 g
Frequency shift = 35.2 %
Diameter= 26.60 cm (Mitte Sicke-Mitte Sicke)
Est-Re = ON
LSE = ON
Wobbel 1h.
Messung Kalt
Signal PN 1V
Kalibriert und Kabel kompensiert.
Re per Messung ermittelt, überprüft per Multimeter.
Masse per kalibrierter Feinwaage ermittelt (0,1g)
Simulation vs. Messung:
Rot: Thomann TSP
Blau: Gemessen
Sw: Messung (geglättet)
			Patameter:
Fs = 67.18 Hz
Re = 6.26 ohms[dc]
Le = 380.92 uH
L2 = 798.66 uH
R2 = 41.93 ohms
Qt = 0,561
Qes = 0.71
Qms = 2.67
Mms = 41,1 g
Rms = 6,49365 kg/s
Cms = 0,0001366m/N
Vas = 59.86 liters
Sd= 555,7 cm²
Bl = 12,36397 Tm
ETA = 2,4859 %
Info:
Est-Re = ON
LSE = ON
Wobbel 1h.
Messung Kalt
Signal PN 1V
Rot: Thomann TSP
Blau: Gemessen
