Kenford PA380 FS-W15-8-50 (Modell 2015) | TSP vermessen
Verfasst: 14. Sep 2015 19:44
Kenford PA380 - FS-W15-8-50 - 8 Ohm - Modell Mitte 2015
Loudspeaker parameters:
Fs = 30.95 Hz
Re = 5.80 ohms[dc]
Le = 187.12 uH
L2 = 761.36 uH
R2 = 25.84 ohms
Qt = 0.442
Qes = 0.51
Qms = 3.31
Mms = 74.62 grams
Rms = 4.38393
Cms = 0.0003544 m/N
Vas = 367.75 liters
Sd = 855.30 cm^2
Bl = 12.84621 Tm
ETA = 2.0789 %
Lp(2.83V/1m) = 96.73 dB
Info:
Added mass = 107.20 grams
Frequency shift = 34.1 %
Diameter= 33.00 cm
Est-LSE = on
Est-Re = on
Wobbel = 5m 35Hz
Signal PN 1V
Kalibriert und Kabel kompensiert.
Re per Messung ermittelt, überprüft per Multimeter.
Masse per kalibrierter Feinwaage ermittelt (0,1g)
Fs = 30.95 Hz
Re = 5.80 ohms[dc]
Le = 187.12 uH
L2 = 761.36 uH
R2 = 25.84 ohms
Qt = 0.442
Qes = 0.51
Qms = 3.31
Mms = 74.62 grams
Rms = 4.38393
Cms = 0.0003544 m/N
Vas = 367.75 liters
Sd = 855.30 cm^2
Bl = 12.84621 Tm
ETA = 2.0789 %
Info:
Diameter= 33.00 cm
Est-LSE = on
Est-Re = on
Wobbel = 5m 35Hz
Signal PN 1V
