McGee PA 250 mm 201848 (Modell 14/15) | TSP vermessen
Verfasst: 23. Sep 2015 15:20
McGee PA 10 Zoll - 201848 - 8 Ohm - Modell 2014/2015
Gelistet als McGee PA Subwoofer 250 mm
Loudspeaker parameters:
Fs = 67.93 Hz
Re = 6.00 ohms[dc]
Le = 326.95 uH
L2 = 853.99 uH
R2 = 44.42 ohms
Qt = 0.75
Qes = 0.81
Qms = 11.25
Mms = 43.92 grams
Rms = 1.66627 kg/s
Cms = 0.0001250 m/N
Vas = 21.27 liters
Sd = 346.36 cm^2
Bl = 11.78370 Tm
ETA = 0.8004%
Lp(2.83V/1m) = 92.44 dB
Info:
Added mass = 47.05 grams
Frequency shift = 30.6 %
Diameter= 21.00 cm
EST RE = On
LSE = On
Wobbel = 60m 40Hz
Signal PN 1V
Kalibriert und Kabel kompensiert.
Re per Messung ermittelt, überprüft per Multimeter.
Masse per kalibrierter Feinwaage ermittelt (0,05g)
Fs = 67.93 Hz
Re = 6.00 ohms[dc]
Le = 326.95 uH
L2 = 853.99 uH
R2 = 44.42 ohms
Qt = 0.75
Qes = 0.81
Qms = 11.25
Mms = 43.92 grams
Rms = 1.66627 kg/s
Cms = 0.0001250 m/N
Vas = 21.27 liters
Sd = 346.36 cm^2
Bl = 11.78370 Tm
ETA = 0.8004%
Info:
Diameter= 21.00 cm
EST RE = On
LSE = On
Wobbel = 60m 40Hz
Signal PN 1V
