Upgrade to Achat 118?
Verfasst: 19. Feb 2023 18:02
Hello, we need some help upgrading our PA. FIrst let me explain what kind of system we have right now.
We have 8 pieces od Achat 115 SUB A, tops are 4 pieces HK audio Linear 5 LTS A.
We ussually set bass speakers in arc array, however sometimes we do it in LR (depending on available space).
We usually set crossover at 120Hz.
Low mid frequencies are usually a bit lacking (120 – 200 Hz) so we would like to upgrade our system with adding 115 subs in the range od 90 – 180 Hz and lower the crossover point of subs.
Ok, let me explain a bit: the idea is to cross main subs (8 x 115 central or 4 x 115 per side) at 90 Hz to low mids (2 x 115 per side) and then at 160Hz to tops (2 x LTS per side).
The other idea is to use 6 Achat 118 (horns) instead of 115 subs for bass and reuse existing subs (time aligned of course) as low-mid.
So, should we just add more 115 subs or upgrade the system with 6 x Achat 118 and maybe later add two more?
Thank you.
Thank you.
